Reset ECU
Reset ECU
Pokoušel se někdo z Vás resetovat ECU dle tohoto návodu... odezvy z ang. fora jsou velice pozitivní...
1. Disconnect battery for 45 mins
2. Reconnect battery, and turn ignition to MAR for 90 secs
3. Turn off and leave 90 secs
4. Start engine WITHOUT pressing throttle and let the car idle for 15 mins (I repeat, do not touch the throttle whilst the car is idling)
5. Turn engine off and leave for 10 minutes
6. Start the car and go for a drive, using a number of styles (eg town, motorway, thrash etc)
pro ty co nevládnou ang:
1. odpojit baterku na 45min
2. připojit a klíčkem otočit do pozice MAR na 90 sekund
3. otočit klíčkem do vypnute pozice na 90 sekund
4. nastartovat ale nepřidávat plyn! a nechat vrčet 15min
5. vypnout motor na 10 minut
6. nastartovat a projet se v různých režimech (město, okrsky a dálnice)
Prý to funguje pro všechny alfy...
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR 156 2.0 selespeed ex
AR 159 SW 1.9 jtdm ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
Re: Reset ECU
nebo připojím FES a smažu autoadaptační data
Re: Reset ECU
jj pry se komplet smazou vsechny data a auto zacne proces uceni znovu. A dle ohlasu jsou to jen bonusy...
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
- lada.blaha
Re: Reset ECU
A k cemu je to dobre ze se tak blbe ptam? :-)
Odesláno z mého GT-I9300 pomocí Tapatalk 2
Alfa Romeo 166 3,0 V6
Fiat Seicento Sporting
Škoda 110R
Škoda 110R
Re: Reset ECU
So I did this, and my GT is reborn ! Faster, smoother, more torqier, even idle - it's bloody fantastic ! I can't believe how different the whole car feels.
It nearly cured the climate problem (well it blows a bit cooler) so if anyone has any tips on how to fix, let me know.
But the cherry on the icing on the cake was something I didn't expect, it seems to have cured my 'stepping' drivers window problem that I had given up on !!
Now the driver's window goes up and down as smoothly as the proverbial baby's bum.
So, if you're thinking of trying the ECU/Throttle reset and you have a hour or two on your hands this festive break, give it a go - it might work miracles for you to !
http://www.alfaowner.com/Forum/alfa-147 ... -cure.html
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
- yan.ko
Re: Reset ECU
No, popravde smazani autoadaptacnich dat udela totez, ale prijdes o hodinu a ctvrt srandykudrt píše:jj pry se komplet smazou vsechny data a auto zacne proces uceni znovu. A dle ohlasu jsou to jen bonusy...
Alfa Romeo Perfection
Re: Reset ECU
posledně ten seznam obsahoval ještě nějaké zaříkadlo a mladou pannu
Re: Reset ECU
ty vole... ta mlada panna mi neco rika
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
- George.KHE
Re: Reset ECU
Kudrt: až to otestuješ, dej mi vědět.
Jinak když mám delší dobu odpojenou baterku, tak si ŘJ nenačítá nové informace stejně jak u toho resetu?
- Dresik
Re: Reset ECU
A ja bych rekl, ze mozna i ano
Alfa Romeo MiTO 1.6 JTDm
Alfa Romeo 75 1.6carb
Lancia Delta HPE HF16v Turbo
Lancia Delta HFIntegrale 8v
Lancia Beta 1300
Fiat Punto Cabrio
Ex-156 GTA,JTDm,...
ITALMOTORI servis
Lancia Beta 1300
Fiat Punto Cabrio
Ex-156 GTA,JTDm,...
ITALMOTORI servis
Re: Reset ECU
George: O víkendu se na to mrknu, tak pak dám vědět...
Klasické odpojení baterky, řeší jen některé okruhy... ne všechny záznamy. Takhle to popisovaly na eng. foru.
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
Re: Reset ECU
takže jsem to prubnul... a u mne nic zásadního....
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
- George.KHE
Re: Reset ECU
Asi to máš dobře zajetý
já to radši zkoušet nebudu. Myslím si, že tam nebude být nějaký zásadní rozdíl, i když na těch alfáckých stránkách to někteří popisují jak navýšení o 50PS
Re: Reset ECU
No prave to mne taky zarazilo. Mozna to jeste prubnu na TSku.. jen pro zajimavost.
AR 159 2.2 jts
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
AR GT 2.0 selespeed
AR 156 2.5 V6ex
AR GT 3.2 V6 ex
Re: Reset ECU
Čau potřeboval bych poradit, připojil sem auto na diagnostiku protože po šlápnutí na plyn se auto lehce zadusilo a pak normálně zvýšilo otáčky jak má, ale byl tam lehkej propad, diagnostika psala špatnej potenciometr plynu (asi u klapky až), pak už to nenapsalo. Když jsme to měl napíchlí, zkoušel sem test všeho, pak jsem dal reset AUTOADAPTIVNÍCH parametrů, auto sem chtěl nastartovat ale nechtělo se mu, pak chytlo a zas chcíplo, pořád se to opakuje a když sem střík do sání benzín a nastartoval tak to chytlo vpohodě, motor běžel asi dokuď nespálil benzín ze sání a zas chcíplo.
Máte stím někdo zkušenost?? nedávno jsem měnil čidlo fáze a chová se to podobně jako když odejde právě to čidlo.
Po tom resetu se musí nechat auto běžet 15 min?
Předem díky za veškeré rady a nápady.
AR 156 1.6 TS 88kW r.v.2001
- kravitzUL
Re: Reset ECU
tak dneska tuhle tajemnou konstalaci vyzkoušim
Čistil jsem škrtící klapku a od té doby svítí kontrolka motoru, protože při druhém zapojení, se špatně připojila el. Budu stejně nasazovat nová kola a čistit brzdy takže času dost a venku je pěkně. Tak pak napíšu jestli je z toho GTA a nebo něco více
GT 3.2 bussánek Q2
166 2.4 Jtd, 129 kw
ex - 159 1.9 JTDm, 110 kw
156 SW, 1.9 JTDm
156, 1.8TS, Sportpacket
33, 1.7, 16V, 97 kw
33 1.4 boxer Imola , 65kw
GT 3.2 bussánek Q2
166 2.4 Jtd, 129 kw
156 SW, 1.9 JTDm
33, 1.7, 16V, 97 kw
