Podložky pod RZ a vše kolem
nicoalfa
Příspěvek od nicoalfa » 20.2.2018, úte 17:32
Ahoj, sorry for don't speak Cesky.
Some weeks ago I asked on this forum about if in CZ exist small number plates like in Italy or Swiss... the answer was not :-(
The thread was erased... so, I can't answer in the same post.
I find out one system with "velcro" for make more nice our CZ number plates. Here are the photos of my car.
Before:
After:
I only hope that the glue will be strong.
Re: Nice number plate for our Alfas
Příspěvek od speedy » 20.2.2018, úte 18:03
it will be good I think, because number plate on the front is pulled by headwind :D
qpkqkma
Příspěvek od qpkqkma » 20.2.2018, úte 18:05
Ok. I´ll try to answer you for this...so, no official small size number plates for Czech/Slovak, I´m sorry :/
Second one... I know a few people use glue for metals (you can buy it almost everywhere) or that "Velcro" system looks interesting, but i´ll be worried about my plate, especially in higher speeds etc...
Get us know if it´s strong enough :D
nicoalfa
Re: Podložky pod RZ a vše kolem
Příspěvek od nicoalfa » 21.2.2018, stř 18:14
At the moment it has endured a month, with snow and low temperatures.
qpkqkma
Příspěvek od qpkqkma » 21.2.2018, stř 19:09
Do you ride on motorways often ?
hno3
Příspěvek od hno3 » 22.2.2018, čtv 06:08
I had my plate glued with MAMUT Glue... with wich i also glued side skirts on my previous car
It hold safely for years but can there be problem with cleaning area when removing it..
AR 159 SW TBI TI
AR 156 V6 SW
AR Giulietta 1.4 MA
Fiat Coupe 2.0 16v
Fiat Tipo 2096ccm 16v
nicoalfa
Příspěvek od nicoalfa » 22.2.2018, čtv 16:34
qpkqkma píše: 21.2.2018, stř 19:09 Do you ride on motorways often ?
Not.
Around 5000km per year.
With 3.2 I can't do a lot of km :-D
nicoalfa
Příspěvek od nicoalfa » 22.2.2018, čtv 16:37
hno3 píše: 22.2.2018, čtv 06:08 I had my plate glued with MAMUT Glue... with wich i also glued side skirts on my previous car
I know MAMUT Glue, its very famous in CZ.
This Velcro system says that is glue for cars and plate numbers. So, I hope that they think about how to remove without problems from the car.
qpkqkma
Příspěvek od qpkqkma » 22.2.2018, čtv 17:16
Yeah, but one you put MAMUT glue, you´ve no chance to take it down without damaging bumper :D
romanc
Příspěvek od romanc » 23.2.2018, pát 23:22
Ja jsem spz prilepil oboustranou paskou. Osobne jsem pouzil Akryl gel AFT.
Uz predtim jsem ji pouzival v aute (dascam, prilepeni hid balastu) a v domacnosti (napr 2 roky drzi velke a tezke zrcadlo 1,5m x 2m) a neni s tim zadny problem.
Sice na prvni pohled to vypada ze nic neudrzi (jak je gelova tak se velmi snadno roztahuje), ale jak to prilepis a pritlacis tak musis vynalozit velmi velkou silu na odtrhnuti. A navic to nijak neposkozuje spojovane materialy a gel pohlcuje cast vibraci.
I have a number plate attached with a double-sided tape. I personally used an acrylic gel tape AFT.
I've used it before in my car (dashcam, hid xenon balast) and at home (for example, 2 years holding a heavy mirror 1.5m x 2m) and there is no problem with it.
Although at first glance it seems to hold nothing. Because gel is very easy to stretch, but as you stick it and press it hard, you have to have a very strong force to tear it off. And, moreover, it does not harm the connected materials and the gel absorbs the vibration.
Opel Corsa 1.4T 74KW 2018
Příspěvek od Adamsquare » 24.2.2018, sob 10:44
Glue? The screw never die :wink:
nicoalfa
Příspěvek od nicoalfa » 24.2.2018, sob 10:57
romanc píše: 23.2.2018, pát 23:22 Ja jsem spz prilepil oboustranou paskou. Osobne jsem pouzil Akryl gel AFT.
Perfect!!! I like your solution.
nicoalfa
Příspěvek od nicoalfa » 24.2.2018, sob 11:00
Adamsquare píše: 24.2.2018, sob 10:44 Glue? The screw never die :wink:
Wow, my wife say me that this is illegal on CZ.
In my country (Catalonia), all cars use screws for number plates. This is the reason why I tried find another solution with glue/velcro.
MikeC
Příspěvek od MikeC » 24.2.2018, sob 15:27
I really doubt screw is more ilegal then taping/glueing the plates to the bumber :)
Toyota Corolla TS 1.8 2023
Jakub_mt
Příspěvek od Jakub_mt » 24.2.2018, sob 18:27
May be as the screw is integrality disruption of plate and this is (at least in Slovakia) illegal.
Příspěvek od Adamsquare » 24.2.2018, sob 21:27
Přímo v návodu značky je uvedeno, že lze použít podložku nebo šrouby.
Screws are alowed here.
Příspěvek od Adamsquare » 24.2.2018, sob 22:36
WTF? místo obázku tam skáče nějaká reklama :shock:
Naposledy upravil(a) Adamsquare dne 2.3.2018, pát 13:51, celkem upraveno 1 x.
Boomer
Příspěvek od Boomer » 25.2.2018, ned 08:19
Jakoze me muzou vyhodit na STK kdyz mam prisroubovany SPZtky? :shock:
romanc
Příspěvek od romanc » 25.2.2018, ned 10:06
Srouby muzes pouzit, ale nesmi jakkoliv zasahovat do znaku, vlajky a textu. Navic musi byt zakryty ci zabarveny aby nebyly videt. Co neni povoleno jsou nyty.
Screws can be used but must not interfere with the character, flag and text. Moreover, they must be covered or tinted to not be visible. Rivets are forbidden.
Příspěvek od rosso155 » 25.2.2018, ned 13:27
Máme na velkejch značky normálně přišroubovaný, auta, vleky i návěsy, klasickejma vrutama bez nějakých krytek, STK děláme každej rok, a žádnej problém.
nicoalfa
Příspěvek od nicoalfa » 25.2.2018, ned 15:26
Very thanks for the info guys.
yetyGT
Příspěvek od yetyGT » 4.5.2018, pát 07:38
Jakub_mt píše: 24.2.2018, sob 18:27 May be as the screw is integrality disruption of plate and this is (at least in Slovakia) illegal.
It is not illegal. You just have to make sure it will remain readable.
Jakub_mt
Příspěvek od Jakub_mt » 4.5.2018, pát 15:04
§123 zákona o cestnej premávke
(4) Držiteľ vozidla je povinný vydanú tabuľku s evidenčným číslom bezodkladne pripevniť na vozidlo. Tabuľka s evidenčným číslom nesmie byť pripevnená spôsobom, ktorý narušuje jej celistvosť a znemožňuje jej čitateľnosť alebo identifikáciu. Ak boli vozidlu vydané dve tabuľky s evidenčným číslom, držiteľ vozidla je povinný bezodkladne pripevniť na vozidlo obe tabuľky.
yetyGT
Příspěvek od yetyGT » 4.9.2019, stř 13:58
Jakub_mt píše: 4.5.2018, pát 15:04 §123 zákona o cestnej premávke
