Repas podvozku
FERRARIST
Re: Repas podvozku
Příspěvek od FERRARIST » 20.10.2013, ned 18:10
cepppp píše:jinak jsem prošel stranky toho Bulhara a je to velkej tuner :D
http://s1020.beta.photobucket.com/user/ ... rt=3&o=124
Really sorry if i breach your forum rules writing in english here, but i saw a web traffic from your site and being Bulgarian Alfisti i'd take a look here.
We are the manufacturer of these PU bushes. We first started 6 years ago with 156's and then 166's was second on our list.
Saw that your are interested in rear axle bushes and here is some info about it.
Set of 1-111 and 1-112 for one car(4 bushes) is 68 EU with postage included to entire EU......
Set of 1-113(4 bushes for 1 car) is 39EU if ordered WITH above bushes.
Both 1-120 for one car are 27eu, if ordered with one of above sets.
Thanks again.....
P.S - don't know if Google translate "a je to velkej tuner" correctly, but i'm just trying to combine passion and work.
And make some unusual car mods like moving engine of my trackday 156's on the back....
http://www.youtube.com/watch?v=4ErGozsG1x4
166 zos.jpg (7.9 KiB) Zobrazeno 4966 x
Rear Wheel Drive Mid - Engined Alfa 156 3.0 V6 '99 - trackday car
Alfa 156 2.0 TS '00 - daily car
Fiat Coupe 20VTurbo, GT2860RS, water-meth injection 120cc, custom manifold, 3" Downpipe, FMIC - entertainment car
petto396
Re: Repas podvozku
Příspěvek od petto396 » 4.1.2014, sob 10:48
Zdravim neviete kde zohnat horne ramena najlepsie TRW za lepsiu cenu ako cca 75€ kus? mam moznost dat starline nove za 30€ tak neviem
Zip166JTD
Re: Repas podvozku
Příspěvek od Zip166JTD » 10.2.2014, pon 17:31
Pánové omylem mi zůstala tahle sada strongflexu. Je to zadní silentblok zadního spodního ramene(bumerng). Kdyby měl někdo zájem. Nechám to za prodejní cenu.
http://www.strongflex.eu/pl/alfa-romeo- ... sport.html
Re: Repas podvozku
Příspěvek od Richie » 10.2.2014, pon 19:37
Reknu servisakovi at to u me omrkne
vonkreuz
Re: Repas podvozku
Příspěvek od vonkreuz » 14.3.2014, pát 10:57
Otázka do pléna:
Když zatáčím doleva, tak mám pocit, že mi více hučí LP kolo. Nevím, zda mi odchází ložisko nebo to je zimníma pneumatikama. Jsem z toho trochu nervozní. :shock:
Když auto zvednu a budu točit kolem, poznám to na zvuku? :-k
A druhá otázka, je nutný při výměně ložiška stahovák nebo jiný speciální nástroj? :-k Že bych to kdyžtak kuchl doma... Kdyžtak si udělám výlet ke Carschovi a Aleně.
alfi166silver
Re: Repas podvozku
Příspěvek od alfi166silver » 14.3.2014, pát 13:33
Na straně 2 tohoto vlákna máš ode mě návod na výměnu předního ložiska, dvouramennej stahovák se bude hodit a momenťák taky
http://www.alfisti.cz/forum/viewtopic.p ... 0&start=25
AR 159 SW 2,4 JTDm 147 kW
vonkreuz
Re: Repas podvozku
Příspěvek od vonkreuz » 14.3.2014, pát 13:38
Děkuji guru. :supz:
Jak to tak čtu, mám z toho osypky. :twisted:
alfi166silver
Re: Repas podvozku
Příspěvek od alfi166silver » 14.3.2014, pát 13:51
Pokud máš veškeré potřebné nářadí, jde to dobře.
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 14.3.2014, pát 14:36
Ludia tento vikend sa konecne pustim do zadnej napravy. Unibali mam nove, teraz sa budu menit silenty v spodnych ramenach a ulozenia stabiku za PU. Som silno zvedavy co to povie :smt026
ex.Alfa Romeo 156sw 3.0V6 24v
ex.Lancia Thesis 3.0v6 24v
ex.Alfa Romeo 147 1.9jtd 85kw
vonkreuz
Re: Repas podvozku
Příspěvek od vonkreuz » 14.3.2014, pát 20:57
Tak jo, zatím to vypadá na ložisko. Levý disk je zahřátější než pravý.
edit: jak tak koukám na díly (Kelly, Automedik, autodielymt.sk, ...) tak všude se prodává ložisko rovnou s domkem, ale samotné ložisko nevidím.
Neví, prosím někdo číslo přímo ložiska, nebo jeho rozměry či jiné parametry? Kamarád pracuje ve vývoji v INA (Schaeffler), tak bych to zkusil sehnat přes něj. :-k
alfi166silver
Re: Repas podvozku
Příspěvek od alfi166silver » 15.3.2014, sob 09:31
Ono jinak než s domkem to nejde.... Ten domek je myšleno "límec" s dírama pro šrouby, to bych přelisovávat určitě nechtěl....Ložisko bude mít určitě atypický rozměr, otázka je jakou má skutečně radiální vůli, jestli C3 nebo jinou a riziko při lisování ložiska do domečku, že jedno nebo druhe se zk*rví je značné..
Yboris
Re: Repas podvozku
Příspěvek od Yboris » 16.3.2014, ned 21:46
Prelisovat to nejde, protoze venkajsi kruzek je monolit ze srobama to znamena ze to je jeden kus aj z venkajsim kruzkem drah, vnutorny kruzek je standard na hridel ale inak jak z nabojem som to ve vyrobe nevidel, pokud ti huci a nekrupe tak ma vypadane kulickove drahy na ztuhlu vazelinu jelo suche.Exzistuje aj standard ale venkovny kruzek ma velikost skoro stejnu jak tento special z usima na sroby, takze sa neda kvoli rozmeru na tehlici dat ani do priruby, bolo by to velke.
vonkreuz
Re: Repas podvozku
Příspěvek od vonkreuz » 20.3.2014, čtv 20:53
Další lamovská otázka. Kdosik kdesik psal, že do čepu stříká jakousi směs oleje či čehosi pomocí injekční stříkačky pro delší životnost a zachování kluznosti a zabránění vrzání...
Takže třeba grafitovku po feťácku nahřát na lžíčce nebo v konzervě od májky, nasát a vpichem vpravit? :-k
Re: Repas podvozku
Příspěvek od Danni » 20.3.2014, čtv 21:06
to som pisal asi ja... ak mas rameno vonku tak netreba nic pichat... ale inak staci normal olej, stary prevodovy je celkom tekuty tak ten sa daval celkom fajne a ak mas rameno vonku tak po oleji trochu vazeliny nech utesni hrdlo potom vopchat srubovak abo nejaku palicku stlacit prachovku pokial nebude v polohe ako bude na aute a bude to ok... no ak prachovka sfukuje a proste niekde prechadza vzduch tak to je problem, musi to byt vzduchotesne
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 20.3.2014, čtv 23:10
Tak tak . Presne ako pise Danni. Stiahnut z prachovky ten mali kovovy kruzok , niecim nie ostrim otvorit prachovku a narvat tam vazelinu. opatrne nasadit kruzok a mas svaty pokoj.
Mam to takto poriesene na hornych ramenach, spodnych a tiez aj predne a zadne tycky stabikov.
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 21.3.2014, pát 22:56
screenshot windows 8
Takze trosku k mojmu spominanemu repasu zadnej napravy. Obidve ramena dostali strongflexi.
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 21.3.2014, pát 23:01
screen shot on windows
4 silenty ktore drzia napravu o karoseriu som sa rozhodol trosku upgradnut. Na STK som si vsimol ze pri skusani zadnej napravy bola najvacsia vola prave tam. Odvrtal som dolu spodne podlozky a flexou skratil cap o par mm.
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 21.3.2014, pát 23:05
capture
Po stiahnuti celeho silentu srobom sa to pekne stiahne a je to tuhe a bez vole.
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 21.3.2014, pát 23:09
free screenshot
ulozenia stabiku boli kedysi menene FEBI, takze som bol usetreny odsekavania a podobne. Box vie kolko mali rokov ale su vymagane jak blato. Volba padla na PU ulozenia nech je s tym pokoj.
ferdopd
Re: Repas podvozku
Příspěvek od ferdopd » 22.3.2014, sob 18:06
No asi ti dám moju alfinku na operáciu :-) bo uz zadna naprava potrebuje ozdravenie :-) vidím ze teba to baví .
MarekPD
Re: Repas podvozku
Příspěvek od MarekPD » 23.3.2014, ned 10:04
Pekna práca Erik, hlavne tie zrezane 4 silenty na napravnici, zaujimavy napad :) A prečo si volil rôzne farby/tvrdosti na spodnom ramene?
Alfička 159 2,4JTDm
radlo
Re: Repas podvozku
Příspěvek od radlo » 23.3.2014, ned 14:46
marek to mu tak poslali polaci.ericek donesiem tii moju a mozme ju spravit a potom si ju vymenim len. :D ako teraz funguje?
Erik166
Re: Repas podvozku
Příspěvek od Erik166 » 23.3.2014, ned 15:25
joj chalani pekne sa pozera na tie fotky ale keby viete kolko nervov a casu je za tym vsetkym. vedel by som si to predstavit aj kvalitnejsie zrepasovane ale nemam prostriedky a tolko casu. okrem toho je to daily car takze hlavne je aby sa jazdilo.
hondar
Re: Repas podvozku
Příspěvek od hondar » 24.3.2014, pon 09:02
Zadní nápravnici jsem zkoušel řešit stejným způsobem, ale fungovalo to tak měsíc a ještě ne na 100 %... :smt013 Nakonec jsem musel přelisovat všechny čtyři silenty, protože jízda byla jak na žvejkačkách..Naštěstí poradil u nás v Mostě Alfisilver a za všechny silentbloky jsem dal 996,- Kč. :smt023 Jen nebyly origo na alfici, ale na vectru.Zdar
Zip166JTD
Re: Repas podvozku
Příspěvek od Zip166JTD » 24.3.2014, pon 21:50
Hondar nevíš jaké přesně silenty a z jaké Vectri to bylo.
Zpět na „166“
